The 20 gun ship Sphinx 1775 at 1/48
+19
Jean-Paul Rey
Alex_M
23 participants
Page 1 sur 7
Page 1 sur 7 • 1, 2, 3, 4, 5, 6, 7
The Sphinx was a 20 gun ship designed by J. Williams, and was smallest 6th rate frigate. She was built in 1775 at Portsmouth, Hampshire and broken ap in 1811. The Sphinx class ships was also the last class of small frigates armed with 9 pdr guns. There are 10 further ships build to the design:
Camilia, Chathan Dyd, 20.4.1776-1809
Daphne, Woolwich Dyd., 21.3.1776-1802
Galatea, Deptford Dyd., 23.3.1776-1783
Ariadne, Chatham Dyd., 27.12.1776-1814
Vestal, Plymonth Dyd., 23.35.1777-1777
Perseus, Randall, Rothehille, 20.3.1776-1805, 1798 convertet to a bomb vessel
Unicorn, Randall, Rothehille, 23.3.1776-1787
Ariel, Perry & Co., Blackwall, 7.7.1777-1779
Narcissus Plymonth Dyd., 9.5.1781-1796
For this model I have ordered the original plans from NMM, and I have decided to redraw the plans for model building. For decorative work and also some other details I have ordered the pictures from "Science and Society Picture Library" http://www.scienceandsociety.co.uk/results.asp?image=10325356 . For dimensions of all hull details I have used the Establishment lists and other contemporary sources, and Steels "The Elements of masting and Rigging" for mast, yards and rigging.
The preview images of completted plans you can find here: http://zope.mein-media.de/meinmedia/plans/index.html
In February 2006 the plans were ready, at least so far that I have begun with the building of the model. Parallel and in addition I have done further research, and the plans are further worked out.
Now the images:
Le Sphinx était un navire de 20 canons conçu par J. Williams et il était la plus petite frégate de 6e classe. Il a été construit en 1775 à Portsmouth, dans le Hampshire, et démoli en 1811. Les navires de la classe Sphinx étaient également la dernière classe de petites frégates armées de canons de 9 livres. Il y a 10 autres navires construits de la même conception:
Vestale, Plymonth Dy d., 23.35.1777-1777
Perseus, Randall, Rothehille, 20.3.1776-1805, 1798 converti en bombardier
Licorne, Randall, Rothehille, 23.3.1776-1787
Narcisse Plymonth Dyd., 9.5.1781-1796
Pour ce modèle, j'ai commandé les plans originaux à NMM et j'ai décidé de les redessiner pour la construction de modèles.
Pour des travaux de décoration et d'autres détails, j'ai commandé les images de la "Bibliothèque d'images de la science et de la société" http://www.scienceandsociety.co.uk/results.asp?image=10325356 .
Pour les dimensions de tous les détails de la coque, j’ai utilisé les listes "Establishment" et d’autres sources contemporaines, ainsi que Steels "Les éléments de la mature et du gréement" pour le mât, les vergues et le gréement.
Les images d’aperçu des plans complets que vous pouvez trouver ici : http://zope.mein-media.de/meinmedia/plans/index.html
En février 2006, les plans étaient prêts, du moins jusqu’à présent, j’ai commencé à construire le modèle. Parallèlement et en plus, j'ai effectué d'autres recherches et les plans sont encore complétés.
Maintenant les images:
Now the images:
Alex_M- Messages : 73
Re: The 20 gun ship Sphinx 1775 at 1/48
The model was then put in right position, wales are painted black with acrilic paint and then hul was oiled with linseed oil bellow the main wales
Le modèle a ensuite été placé dans la bonne position, les préceintes sont peintes en noir avec de la peinture acrylique, puis la coque a été huilée avec de l'huile de lin sous les préceintes.
Bonjour Alex, je suis ravi de te voir sur ce forum pour suivre tes modèles car sur le forum Anglais j'avais beaucoup de difficulté à te trouver.
Bien venue
Bien venue
isalbert- Messages : 755
Alex,
Très belle réalisation et belles images.
J'attends la suite.
Alex
Very nice achievement and beautiful images.
I'm waiting for what's next.
J'attends la suite.
Alex
Entièrement d'accord avec Francis : c'est une belle réalisation !
____________________________________________________________________________
Completely agree with Francis : it's a beautiful achievement !
péji- Messages : 1145
Ce modèle est un plaisir .
radiau- Messages : 272
thank you all for warm words about my model! merci beaucoup!
Hello,
Here some images of gratings, hatches, ladders and gun deck framing, is now completed and is ready for planking.
The lower deck is also completed and oiled, the after part is painted black.
These are also some close views of main ladder and other things.
Ici, quelques images de caillebotis, des panneaux, d’échelles et d’encadrements de ponts qui sont maintenant terminées et prêtes pour le bordage.
Le pont inférieur est également terminé et huilé, la partie arrière est peinte en noir.
Ce sont aussi des vues rapprochées de l’échelle principale et d’autres choses.
le Spahi aime ce message
some photos of manufacturing of deck planks with caulking. The first photo shows the complete process. The paper was glued to one surface of the prepared piece of wood, then the piece are cut in to planks. I used the Proxxon steel saw blade 50 x 0,5mm (photo 2). It gives very clean cut and does not need for sanding before gluing.
Quelques photos de fabrication de planches de pont avec calfatage. La première photo montre le processus complet. Le papier a été collé sur une surface du morceau de bois préparé, puis le morceau est coupé en planches. J'ai utilisé la lame de scie en acier Proxxon 50 x 0,5mm (photo 2). Il donne une coupe très nette et ne nécessite pas de ponçage avant le collage.
(note an additional piece for fence is that the plank would not be clamped)
The planking of deck:
matiz aime ce message
matiz et le Spahi aiment ce message
Hallo Alexander !
Sehr schöne Arbeit, viel Sorgfalt und Genauigkeit, ich freue mich sehr dich in diesem Forum zu sehen ... Austausch von guten Prozessen !
Lass uns träumen.
(Genau wie du, glaube ich, habe ich ein altes EMCO UNIMAT von meinem Vater geerbt, Anfang der 60er Jahre in Freiburg gekauft und immer tadellos : deutsche Qualität !)
Ein großes Dankeschön für diese Fotos.
Très beau travail, beaucoup de soin et de précision, je suis très heureux de vous voir dans ce forum ... Échange de bons processus !
(Tout comme vous, je crois, j’ai hérité de mon père, un vieux EMCO UNIMAT acheté à Fribourg au début des années 60 et toujours impeccable: qualité allemande !)
Un grand merci pour ces photos
Lass uns träumen.
Hallo Patrick,
vielen Dank! Es ist nur der Anfang, ich habe sehr viel Fotos, die kommen noch nach und nach.
Die UNIMAT ist nicht deutsch, die wurde in Österreich produziert
PS Kannst Du das für die anderen ins französich übersetzen?
Schönen Gruß
Merci ! Ce n'est que le début, j'ai beaucoup de photos qui arrivent encore progressivement.
L’UNIMAT n’est pas allemand, il a été fabriqué en Autriche.
PS Pouvez-vous traduire cela pour les autres en français ?
Belles salutations
Alexander
Schönen Gruß
Belles salutations
Alexander
Bonsoir Alexander,
Le chat est magnifique !
Page 1 sur 7
