Le Deal du moment : -27%
Grosse promo sur le stabilisateur DJI Osmo Mobile 3 ...
79.99 €
The 20 gun ship Sphinx 1775 at 1/48
Page 4 sur 5 Précédent  1, 2, 3, 4, 5  Suivant
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Empty Re: The 20 gun ship Sphinx 1775 at 1/48
Message  Alex_M Jeu 15 Nov 2018 - 19:48
Hello,
further work on cabin bulkheads, deck beams and knees.
Poursuite des travaux sur les cloisons de cabine, les baux de pont et les courbes.
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-118
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-117
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-119
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-121
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-120
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-122
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-125
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-123
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-124
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-126
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-128
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-127
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-130
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-129
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-131
production of stanchions for the ladderway rails. The images are mostly self explanable, I hope Wink
They are turned on Unimat from 1,5mm brass road. Then finished with steel whool on Dremel Tool. The rings are from 0,3mm brass, the rails from 0,4mm.
Production des batayoles pour les mains courantes des écoutilles. Les images sont pour la plupart explicites, j'espère;)
Ils sont tournés sur un Unimat à partir d'un rond de laiton de 1,5 mm puis finis avec de la laine d'acier sur une Dremel. Les anneaux sont en laiton de 0,3 mm, les traverses de 0,4 mm.
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-134
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-133
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-132
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-137
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-136
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-135
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-138
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-140
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-139
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-141
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-143
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-142
Best Regards
Alex
Alex_M
Message  Michel Saunier Jeu 15 Nov 2018 - 20:42
C'est du très beau travail, exemplaire. Mais ce qui me chiffonne ce sont ces encastrements droits des baux sur les Bauquieres. La fonction de maintien d'écartement n'existe donc pas sauf erreur de ma part.
Message  gérard 2 Ven 16 Nov 2018 - 8:56
il semblerait, à la vue des photos, que ce maintien est assuré dans le sens vertical, entre bauquières et gouttières ?
Message  a.piot Ven 16 Nov 2018 - 9:02
Tres beau travail The 20 gun ship Sphinx 1775 at 1/48 - Page 4 743347 The 20 gun ship Sphinx 1775 at 1/48 - Page 4 743347 The 20 gun ship Sphinx 1775 at 1/48 - Page 4 743347
Message  Pierre Blanc Ven 16 Nov 2018 - 13:50
Michel Saunier a écrit:... La fonction de maintien d'écartement n'existe donc pas sauf erreur de ma part.
Ce sont peut-être les courbes qui vont assurer cette fonction.
Message  Michel Saunier Ven 16 Nov 2018 - 13:55
Oui, je ne vois pas d'autres solution.
Message  Alex_M Dim 18 Nov 2018 - 20:10
Hello and many thanks for your comments!
Michel, I hope I have right understand you question... The deck beams in british ships are not tablet in to waterways as by frensh pratice. They are scored in to deck clamp by 1 to 1,5 inch and are supported by logging and hanging knees. The waterway was not scored in to beams, just layed over and bolted to them. In the "Remarks of the Navies of the English..." from B. Ollivier is a good description of english practice.
Bonjour et merci beaucoup pour vos commentaires!
Michel, j'espère que j'ai bien compris votre question ... Les baux de pont des navires britanniques ne sont encastrés dans les gouttières, comme le veut la pratique habituelle. Ils sont encastrés dans la bauquière de 1 à 1,5 pouce et sont soutenus par les courbes. La gouttière n’était pas entaillée dans les baux, mais simplement posée et chevillée. Dans "Remarques des marines des Anglais ..." de B. Ollivier est une bonne description de la pratique anglaise.
Best Regards
Alex
Alex_M
Message  Alex_M Lun 19 Nov 2018 - 19:38
Hello,
making handles of chain pumps. The images show main steps from alignment to installing. The axle is from 1mm brass rod, the crank handles from 0,8mm rod, all soldered together.
Fabrication des poignées de pompes à chaîne. Les images montrent les étapes principales de l'alignement à l'installation. L'axe est constitué d'une tige en laiton de 1 mm, les manivelles d'une tige de 0,8 mm, toutes soudées ensemble.
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-146
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-145
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-144
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-147
Alex_M
Message  Alex_M Lun 19 Nov 2018 - 19:43
the work continues with the gratings and coamings of the quarter deck, and ladder way to gun deck. In this case the gratings should look like "real" and have proper thickness and shape. Follow images show the process. First the upper edge of the block was shaped on this jig:
Les travaux se poursuivent avec les caillebotis et les hiloires du gaillard d'arrière et de l’échelle vers pont. Dans ce cas, les caillebotis doivent ressembler à des "vrais" et avoir une épaisseur et une forme appropriées. Les images suivantes montrent le processus. D'abord le bord supérieur du bloc a été formé sur ce gabarit:
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-150
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-148
then cuts are done on tablesaw:
Les entailles sont faites à la scie circulaire :
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-149
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-151
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-153
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-152
then strips are glued and the whole was sanded again in the jig:
Puis les lattes sont collées et l'ensemble est ensuite poncé :
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-154
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-155
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-156
Coamings are build around gratings, ladder way and coaming added:
Les cadres sont construits autour des caillebotis. Cadres ajoutés :
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-159
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-158
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-157
Alex_M
Message  Alex_M Lun 19 Nov 2018 - 19:51
Have prepared my Unimat to turn and mill the spindle for capstan. The images show the proces.
J'ai préparé mon Unimat pour tourner et fraiser la mèche du cabestan. Les images montrent les processus.
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-160
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-162
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-161
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-163
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-164
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-165
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-168
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-166
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-167
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-169
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-170
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-171
I cut a notch in to inner edge of whelps and then filed the edge to pass them to the barrel. The images show the process explanably I hope...
J'ai coupé une entaille dans le bord inférieur de la mèche et j'ai ensuite collé les taquets pour le tournage. Les images montrent le processus de manière explicite, j'espère ...
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-175
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-174
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-173
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-178
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-177
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-176
The "metal" is black paper  Very Happy
Le métal est du papier noir
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-180
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-179
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-181
The upper capstan was made the same way:
La cloche supérieure est fabriquée de la même façon :
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-182
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-184
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-183
Some close up views:
Quelques vues d'ensemble :
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-185
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-187
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-186
Best Regards
Alex
Alex_M
Message  péji Mar 20 Nov 2018 - 8:37
Hi Alex!
Beautiful work, it is superbly done.
Can you explain a little more in detail the modifications made on the Unimat to realize this capstan ? One or two small documented drawings maybe ... Especially on this piece.
I understand that this is a manual guide to position the faces to be machined, but how did you determine the points ? Annex question, where do you get the basic material for this disc and the different wedges supporting the small drill?
Good day and thank you for these pictures!
_________________________________________________________________________________________________________________________
Salut Alex !
Magnifique travail, c'est superbement réalisé.
Peux-tu expliquer un peu plus en détail les modifications effectuées sur l'Unimat pour réaliser ce cabestan? Un ou deux petits dessins documentées peut-être ... Notamment sur cette pièce. Je pense comprendre qu'il s'agit d'un guide manuel pour positionner les faces à usiner, mais comment as-tu déterminé les points ? Question annexe, où te procures-tu le matériel de base pour ce disque et les différentes cales supportant la petite perceuse ?
Bonne journée et merci pour ces photos !
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-111
Message  a.piot Mar 20 Nov 2018 - 9:00
super travail , et des montages machine tres bien pensés The 20 gun ship Sphinx 1775 at 1/48 - Page 4 743347
Message  Francis Jonet Mar 20 Nov 2018 - 9:38
Je n'avait pas fait attention à ce montage, c'est brigrement ingénieux !
Bravo Alexander.
Message  J-P Ducret Mar 20 Nov 2018 - 15:23
Cette idée de " diviseur " sur l'axe du tour est ingénieux certes mais demande le démontage du capot moteur et un encombrement différent de l'espace tournant du tour et donc espace plein de danger. affraid Il est vrai que que le tour au cours de cette opération ne tourne pas mais nécessite donc montage et démontage pour ces opérations.Le tour devient un outils complexe , à la fois fraiseuse et diviseur . Pourquoi pas ! Il n'en demeure pas moins que tout cela est rudement bien fait et réalisé.
Bravo Alex.
J-Pascal
Message  gérard 2 Mar 20 Nov 2018 - 16:58
c'est effectivement une bonne idée. Et grâce à la grande dimension du disque , la précision doit être bonne.
pour être super-sécurisé, il pourrait y avoir un fin de course qui coupe l'alimentation du moteur quand le capot est démonté.
Qu'en dit l'inspecteur du travail ? The 20 gun ship Sphinx 1775 at 1/48 - Page 4 100992
Message  Alex_M Mar 20 Nov 2018 - 23:57
Hello and thank you for comments!
Patrick, it is dividing disk with 10, 12 and 16 holes. I have drawn them in CorelDraw, then printed and glued to 2mm aluminium sheet. I have mounted them directly to pulley. J-Pascal is right, I can't use the Unimat with this setup for turning, only for milling. The assemby and disassembly takes just few minutes Very Happy
I have bought aluminium sheets here: https://www.metall-kunststoffhandel.de/
Bonjour et merci pour les commentaires !
Patrick,c'est un disque diviseur avec 10, 12 et 16 trous. Je les ai dessinés dans CorelDraw, puis imprimés et collés sur une feuille d'aluminium de 2 mm. Je l'ai monté directement sur la poulie. J-Pascal a raison, je ne peux pas utiliser l'Unimat avec cette configuration pour le tournage, uniquement pour le fraisage. L'assemblage et le démontage ne prennent que quelques minutes.
J'ai acheté des tôles d'aluminium ici: https://www.metall-kunststoffhandel.de/
Best Regards
Alex
Alex_M
Message  Alex_M Lun 31 Déc 2018 - 19:30
Hello,
the next update: building of fire hearth. Some mix of soft solder and CA glue, brass sheets 0,3 mm and 0,1 mm thickness. Images show the prcess:
Nouvelle mise à jour: la construction de la cuisine. Mélange de brasure tendre et de colle CA, des feuilles de laiton de 0,3 mm et 0,1 mm d'épaisseur. Les images montrent le processus:
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-188
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-190
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-189
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-191
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-192
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-193
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-195
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-196
Soft soldered from 0,1mm brass:
Brasage tendre de laiton 0,1 mm :
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-194
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-198
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-197
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-199
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-200
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-202
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-201
The "chain" ... cooper wire 0,1 mm, knotted...
La "chaîne" ... fil de cuivre 0,1 mm, noué ...
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-203
several trials in the waste box... here the one that looks more or less OK
Plusieurs essais ont fini dans la boîte à déchets ... ici celui qui a l'air plus ou moins OK
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-205
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-204
nearly completted...
presque terminé ...
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-206
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-207
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-208
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-209
It is blackened... was all other as easy, because the glue give a sort of patina around. after several cleaning and cleaning, blackening and re blackening it looks a little like wrong iron... here the result, I think, I can live with them...
Elle est noircie ... c'était tout aussi facile, parce que la colle donnait une sorte de patine. après plusieurs nettoyages et nettoyages, noircissement et re noircissement, cela ressemble un peu à du vieux fer ... voici le résultat, je pense, je peux vivre avec ...
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-211
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-210
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-212
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-214
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-213
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-215
making the base for the stove from 0,3mm wood strips, cut in squares. The first image shows the cutting jig. Second image show some "Stones" with a pencil line I mark before cutting, it's serve as direction guide by gluing. The "stones" are glued to 1mm plywood base.
Fabrication de la protection du pont sous la cuisine à partir de bandes de bois de 0,3mm, coupées en carrés. La première image montre le gabarit de coupe. La deuxième image montre des "Pierres" avec un trait au crayon que je marque avant de couper, elles servent de guide de direction en collant. Les "pierres" sont collées sur une base de contreplaqué de 1 mm.
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-217
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-216
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-218
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-219
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-220
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-221
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-222
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 Post-223
Best Regards/ Bien cordialement
Alex
Alex_M
Message  a.piot Lun 31 Déc 2018 - 20:52
affraid The 20 gun ship Sphinx 1775 at 1/48 - Page 4 743347 The 20 gun ship Sphinx 1775 at 1/48 - Page 4 743347 The 20 gun ship Sphinx 1775 at 1/48 - Page 4 743347 santa
Message  Francis Jonet Lun 31 Déc 2018 - 22:23
C'est superbe de précision ! Je pense que Daniel va être jaloux de cela même si ce n'est pas à la même échelle.
Alexender, en as-tu d'autres comme cela ? Magnifique.
Message  J.Guydal Lun 31 Déc 2018 - 23:00
En suivant ce sujet pas à pas, on ne peut être qu'admiratif d'une telle qualité d'exécution.
C'est motivant pour améliorer son travail bien sûr.
Mais aussi, il devient complexant et difficile de poster derrière cela un modeste projet comme le mien.
Bonne année à tous.
Message  péji Mar 1 Jan 2019 - 7:27
Remarquable qualité dans l'exécution ! Résultat à la hauteur ! Un grand BRAVO Alex !
Message  radiau Mar 1 Jan 2019 - 10:51
Remarquable !
Message  EricLem Mar 1 Jan 2019 - 10:56
magnifique ! et une méthode de réalisation de la chaîne très intéressante.
Message  Olivier Gatine Mar 1 Jan 2019 - 12:25
wunderschön !
http://olivier.gatine.free.fr
Message  G. Delacroix Mar 1 Jan 2019 - 12:57
Traduction effectuée.
Beau travail Alex !
The 20 gun ship Sphinx 1775 at 1/48 - Page 4 52989
Message  Pierre Blanc Mar 1 Jan 2019 - 14:37
Magnifique la cuisine.
